Ansys Learning Forum › Forums › Discuss Simulation › Fluids › UDF for surface reaction rate〈Please help a beginner〉 › Reply To: UDF for surface reaction rate〈Please help a beginner〉
Yuya.S
Thank you for your reply!
I'm probably not even expressing the mole fraction correctly, am I?
Also, is the way I define real TP = C_P(c0,t0) in the macro correct?
Am I correct in understanding that if the mole fraction of each chemical species can be defined correctly, then the partial pressure can be expressed as mole fraction * TP?
