Ansys Learning Forum Forums Discuss Simulation General Mechanical Accessing node temperatures in User Programmable Feature during solution Reply To: Accessing node temperatures in User Programmable Feature during solution
David Weed
Hi, just a correction on DSPGET. After testing, I realize that this is only valid for /post1. For a routine that is valid in /solu, try using NDSPGT instead. And yes, after using #include, you should have access to whichever include deck you specify.
