Ansys Learning Forum Forums Discuss Simulation General Mechanical User defined result for imported geometry Reply To: User defined result for imported geometry
Armin
Hi Kevin,
You can define a path by right-clicking on the "Model" in the project outline and then select insert --> Construction Geometry --> Path.
Once a path is specified, you can simply request the variable of interest (for example, total deformation) to be plotted along the path. Right-click on Solution and select the variable of interest, then for the entry, Scoping Method, select "Path" and finally select your prescribed path defined earlier along the beam.
