Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Can we ask Fluent read a journal file from within another journal file? › Reply To: Can we ask Fluent read a journal file from within another journal file?
Hi Chaitanya,
Thank you for your reply. Do you also have experience with EDEM? I am trying to couple EDEM and Fluent through a windows batch file and nested journal files. EDEM must be connected to Fluent through a coupling server. The connection must be from EDEM side, and the syntax for starting the EDEM with connection to Fluent isÂ
 edem -c -i
when this is run, there will appear the message "Awaiting client connection"
it seems that I should start Fluent before this line so that Fluent gets ready to connect to the EDEM server. Do you have any idea on this?
