Ansys Learning Forum Forums Discuss Simulation LS Dyna Rotation velocity in Workbench ACT LS-Dyna Reply To: Rotation velocity in Workbench ACT LS-Dyna
javat33489
I turned off the displacement but the rotation still doesn’t work for me. Errors appeared:
I added a new condition to the drill and attached two deformable teeth
drill rotation speed 27 rad/s, feed rate 40 mm/s. No tool works with my drill, it does not rotate or pass. Maybe it’s an ANSYS bug? I attached the model of the swerl, can you please make a rotation?
ARCHIVE
