Ansys Learning Forum Forums Discuss Simulation Fluids Fixing Bad Mesh Reply To: Fixing Bad Mesh
It depends. If those cells are in regions with high gradients you'll potentially cause the solver to fail and/or produce poor results. If not much is happening you might get lucky and nothing bad happens.
