Ansys Learning Forum Forums Discuss Simulation Fluids Condensation Reply To: Condensation
Hybrid initialisation may not be the best option, have a look at the results at t=0. Do you have a coupled wall between the cold water & steam?
If you create an iso-surface at x=middle but also select the steam side before applying/creating you'll have a surface that's just in the steam side, that may help with the model review.Â
