Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Getting “Latent Heat can not be less than zero” error in Condensation simulation › Reply To: Getting “Latent Heat can not be less than zero” error in Condensation simulation
June 28, 2023 at 3:49 pm
manuel.pacherres
Hi Emir I just read the problem you had, I just wanted to ask:
The air that you are considering, will be the cooling fluid ? or is that necessarily to perform the condensation process in Fluent you need to enter air ?
