Ansys Learning Forum Forums Installation and Licensing Ansys Products How to setup Icepak so as to utilize multiple cores/threads in a local machine? Reply To: How to setup Icepak so as to utilize multiple cores/threads in a local machine?
steve diaz
Hello
Both classic Icepak and AEDT Icepak use multiple cores for post-processing and data collation, follow these steps:
  1. Enable multi-core processing in the software settings.
  2. Increase solution parallelism by adjusting the settings for how many cores or parallel tasks to use.
  3. Check that the software is set to use multiple cores for post-processing and data collation.
  4. Consider using a batch mode or scripting to automate tasks and take advantage of parallel processing.
  5. Make sure your computer has enough memory (RAM) and fast storage to handle the workload.
  6. If you need more help, consult the software documentation or contact the support team.
By following these steps, you can optimize the use of multiple cores and improve performance during post-processing and data collation in both classic Icepak and AEDT Icepak.
Thank you.
