Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Readable structure file format for Lumerical FDTD › Reply To: Readable structure file format for Lumerical FDTD
Dev
The preferred data format is in Matlab. Matlab preserves the original data and unit.
Since your file is in .txt, you can try using combination of readdata – Script command – Ansys Optics and addpoly – Script command – Ansys Optics to import the geometry in FDTD.
Thanks
