Ansys Learning Forum Forums Discuss Simulation LS Dyna Ignore bulk and shear modulus in UMAT LS_DYNA input parameter? Reply To: Ignore bulk and shear modulus in UMAT LS_DYNA input parameter?
Andreas Koutras
Hello Tuan,
The bulk and shear moduli should be specified.
From Appendix A of the Manual:
"all user-defined material models require bulk and shear moduli for transmitting boundaries, contact interfaces, rigid body constraints, and time-step calculations."
