Ansys Learning Forum Forums Discuss Simulation Fluids QMOM correction included Reply To: QMOM correction included
Yes, I'd see what Fluent gives with time, and then review.  I'm always wary of models that look at the result and then modify it based on another correlation: if the correlation is that good why not use it as a UDF, and if not, why would I trust it over the initial model? Unless it happens to give exactly the result I want..... then I'd publish it! ;)
