Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Position-dependent internal heat generator › Reply To: Position-dependent internal heat generator
Aniket Chavan
python scripting is possible, but you can also create a text file x y z coordinates, and use a formula based on them to create the internal heat generation data.
This text or csv file can be imported in Mechanical using external data.
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/wb2_help/wb2h_MechLoadapp.html
-Aniket
