Ansys Learning Forum Forums Discuss Simulation General Mechanical Moving Pressure load on a surface Reply To: Moving Pressure load on a surface
Noor Ur Rehman
Hi Erik,
Thank you for your response.
This is just a simple geometry and i know it is easy to split the surface into different sections, But my simulation is a bit complicated. I am able to run the pressure load in the form of a cirlce. But in real problem, i should apply the pressure on a selected square area.
Regards
Noor
