Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Stretching Cells Away from a Narrow Gap Face (Cells Per Gap < 1) › Reply To: Stretching Cells Away from a Narrow Gap Face (Cells Per Gap < 1)
sardar.svn
Thanks Rob.
Actually, the baffle does have a thickness, (it was first created as a body and then extracted from the fluid domain in SpaceClaim, if that's what you mean). The images seen in the original post is from Watertight UI before the tank and its baffle are volume meshed.
But, why do you ask?
