Ansys Learning Forum › Forums › Discuss Simulation › Fluids › flow dragging particle › Reply To: flow dragging particle
Marcelo Precoppe
I recommend utilizing Ansys Rocky in conjunction with Fluent for your application. Depending on the extent to which particles affect the airflow, you have the option to select either 1-way coupling or 2-way coupling. Here is an example of airflow moving particles: https://youtu.be/7UP7D54J2wE.
