Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Meshing cylindrical bodies with holes › Reply To: Meshing cylindrical bodies with holes
peteroznewman
After you have the surface and deleted the solid in SpaceClaim, go to the Repair tab and click on Extra Vertices to remove the vertex on all the holes. You don't need them and removing them will give the mesher more freedom to make the highest quality mesh.
