Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Farfield power integration value is larger than source power › Reply To: Farfield power integration value is larger than source power
sagar
I have checked by placing the monitor at different distances from the structure, where an electrical dipole was placed inside the structure and observed a significant change in Transmission, where I am not using any absorbing medium, so the power propagating through the different positions after the structure should be same as there is only air just after my design. Why are the changes happening even with slight movement in the monitor position?
