Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Simulation of Solar collector using Fluent with Solar Loads. Help. › Reply To: Simulation of Solar collector using Fluent with Solar Loads. Help.
June 26, 2023 at 10:12 am
Heat transfer will be by absorption, so what are the material properties & is the tube transparent/reflecting/aborbing energy? Which radiation model as they don't all see the fluid/solid material in the same way.Â
