Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Incoherent Bolt Workload › Reply To: Incoherent Bolt Workload
June 26, 2023 at 6:57 am
There is not contact between the bolt shank and the plate holes since in the geometry the holes are larger than the bolt shank.
In what concerns the contact status between the two plates, in the last loading I have used there is no contact between the two plates (pressure = 0). But in the previous load cases contact was still operating but the results in the workload weren't good anyway.
