Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Exporting Solution Data from Fluent › Reply To: Exporting Solution Data from Fluent
Aditya Lakhotia
I specifically require node values, so I haven't tried cell values. I see this as a common occurrence, a lot of other posts relate to the same problem. The problem is with the export of solution data as ASCII from Fluent, so what is being done to address it?
