Ansys Learning Forum Forums Discuss Simulation General Mechanical How can I analyze the lifting process with ANSYS? 4 lifting holes are provided. Reply To: How can I analyze the lifting process with ANSYS? 4 lifting holes are provided.
Steven Miller
I have a similar lifting problem that I am analysing using springs as the lifting slings. I am applying factored loads to simulate the payload in the frame to a DNV standard. Is it best to apply the preload in the springs first then apply the factored load using a multi-step analysis?
