Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Current leak to the air › Reply To: Current leak to the air
Be Ru
Thanks, it now seems to work, at least for a magnetostatic solution type. However, if I change it to eddy current solver and add e.g. a linear count for the current in the optimetrics, I get the "current leak to the air"-error again. I set the eddy-effect under excitations to coil and core.
