Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Current leak to the air › Reply To: Current leak to the air
Be Ru
Sadly, it still fails after a few passes. The B-vec in the core looks right, but the magnitude of H in the core cant be right. For mesh method, it doesnt improve anything if I change to "Classic" method or back to auto, also enabling/disabling "apply curvilinear meshing to all curved surfaces" or make the mesh finer does not help. Do you have any idea what could be the problem?
Thank you!
