Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Simulation of Venturi tube › Reply To: Simulation of Venturi tube
Nikhil N
The residuals look good. Have you sufficiently resolved the boundary layer? Can you share a mid-section of your mesh?
On a side note, the pressure values obtained from Ansys Fluent are typically gauge pressures (relative to a reference pressure). FYI.
