Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Ansys Maxwell and Ansys Mechanical › Reply To: Ansys Maxwell and Ansys Mechanical
VJ
Hi, do you have the same version of Ansys EDT and Mechanical products installed?
Close all Ansys products.
If yes, go to START > Ansys EM Suite 202x Rx > Modify Integration with Ansys (run as administrator) > click YES.
Now relaunch Workbench and it should display the Maxwell component in the Analysis systems. Drag and drop the component and import your .aedt project and then link it with other Mechanical components.
