Ansys Learning Forum Forums Discuss Simulation Fluids Turubulent viscosity limited and then floating point exception Reply To: Turubulent viscosity limited and then floating point exception
Agung Limowa
yes, that's right the length is 1890m and the 5x5 tunnel size and simulation on 3d. The simulation here are the image of what it says before the error. I am using K-epsilon and it seems didn't help. I tried to reduce URF also didn't help. Is it possible to do such simulation?
