Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Area of each mesh Node › Reply To: Area of each mesh Node
June 19, 2023 at 3:16 pm
You cannot have the area of the "node", as node is the intersection of two edges. You can however, determine the area of the face of the cell or collective cells. If you need to determine the area of single cell or specific cells, you need to use DEFINE macros in UDF. Please refer to the Ansys guide on using UDFs and macros.
