Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to Make the Conformal Meshing through the Interface Option? › Reply To: How to Make the Conformal Meshing through the Interface Option?
Coupled walls are for when you have cells on both sides of a wall, ie it's part of a conformal mesh. Rather than use ancient documentation I strongly recommend using the Help system within the software.
Without seeing any of the mesh & geometry I can't comment. Assuming you do have many cell zones and also added several local sizing commands and/or size functions Ansys Meshing has to evaluate all surfaces/settings to all other surface/settings prior to creating the mesh: that tends to slow things down.
Re mesh independence, have you read up on mesh adaption (refinement) in Fluent? For mesh creation, will Fluent Meshing speed things up?
