Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Negative Drag Coefficient on NACA 0021 aerofoil › Reply To: Negative Drag Coefficient on NACA 0021 aerofoil
If you enter NACA into the search box at the top I suspect you'll find the answers. You've almost certainly not defined the reference area correctly.
