Ansys Learning Forum Forums Installation and Licensing Ansys Products Explicit Dynamics. Problem with opening result file Reply To: Explicit Dynamics. Problem with opening result file
Nadiia Kopiika
Hi, I cleared the solution and tried to solve it again several times, but it did not work. I could start the solution , and it proceeded and I had such error in the end. These difficulties are  in all the output results. I have added the scrin of solver output. There is no information about convergency (as it was in Static Analysis)
