Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to setup a stable sand layer by using Eulerian granular multiphase › Reply To: How to setup a stable sand layer by using Eulerian granular multiphase
June 16, 2023 at 8:13 am
What are you trying to find out? Â
10micron particles will tend to follow the air flow, so think flour rather than sand when it's moving.Â
In the two cases, check packing limit at the initial condition, and monitor mass. Check convergence is acheived: that's the most likely cause of weird things happening.Â
