Ansys Learning Forum Forums Discuss Simulation Electronics Import File to Ansys 2022R2 Reply To: Import File to Ansys 2022R2
Reshmi Raghavan
Please note that the files once solved in 2023 version will not be compatible with the lower version.
If the original file was from a lower version (2022R2 or lower) and then simulated using 2023R1 a back up folder would be created (with a copy of the older version file) automatically in the main folder. The back up file can be used to simulate in the older version.
