Ansys Learning Forum Forums Discuss Simulation Fluids Cyclone separator simulation Reply To: Cyclone separator simulation
Manula Yasas
Following are the setup I used for this. Those are only changes I done in the setup. Other settings are defaults. Can you please check those and give a comment about this application and used models. (Are they ok or not)
I didn’t understand the steps to give two injections and track those injections in results. Can you please explain it again. Following is the mesh i using for the simulation.
Please help me to reduce the incomplete particle trackings and inject two density particles to cyclone separator.
