Ansys Learning Forum Forums Discuss Simulation General Mechanical Error in Black lanczos Eigensolver- Failed to allocate Memory Reply To: Error in Black lanczos Eigensolver- Failed to allocate Memory
Aniket
Hi Bala, it seems the issue of large model, can you try reducing the mesh count while keeping quadratic elements?
As per table 4.3 it may take 374 to 664 GB RAM to solve this model in core.
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/ans_per/perlineqsolv.html%23d0e1145
you may want to try using DSPOPTION https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/ans_cmd/Hlp_C_DSPOPTION.html and force this analysis out of core. Please note you will need about 664 GB hard drive space in that case. Also, that hard drive space should be in the same partition where the temp directory is located:
-Aniket
