Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Exporting results from ANSYS FLUENT 19.2 in HDF5 format › Reply To: Exporting results from ANSYS FLUENT 19.2 in HDF5 format
June 3, 2023 at 12:56 pm
chen chen
Hello, blogger, have you found a way to read the fluent dat file with python? My most research also needs to use python to read the node data (pressure, density, etc.) in the dat file
