Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluid “Leaking” through embedded mesh in LS-DYNA ICFD › Reply To: Fluid “Leaking” through embedded mesh in LS-DYNA ICFD
June 2, 2023 at 7:06 pm
That example works but it uses the CESE cards instead of ICFD. I've found that if I turn off turbulence modeling the "leak" disappears which makes no sense but that has been a solution. I think there's a bug in how the pressure/velocity equations are calculated when there are embedded meshes.
