Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Inserting a command in WB to define nonlinear orthotropic material › Reply To: Inserting a command in WB to define nonlinear orthotropic material
wancheng gao
Hi mj,
A new question comes up. There are 12 load steps. Should I set up the "step selection mode" of the APDL command snippet to "all" ? Or just to "First" would be enough. I tried to set it to "All" and tried to analyze the model, but the analysis was terminated at the commencement of the 2nd load step.
Could you tell me how to use APDL command to define the ANISO material for all 12 load steps?
Thank you!
