Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Nose air flow (Respiratory cycle) simulation with heat and Humidity exchange › Reply To: Nose air flow (Respiratory cycle) simulation with heat and Humidity exchange
June 2, 2023 at 1:41 pm
Break the setup into parts - it's easier to learn and troubleshoot on. I also suggest doing the test runs on a pipe bend. It's near enough the same but will run/fair far more quickly.Â
For the boundaries review Profiles and Expressions. I think the latter would be better. Also consider whether you want to push or pull flow and in which direction.Â
Look for humidity on here - it's simple but not set quite as you've asked for.Â
