Ansys Learning Forum › Forums › Discuss Simulation › Photonics › SPR SWeep result › Reply To: SPR SWeep result
June 1, 2023 at 7:45 pm
GWANG
Hi aygün ateşoğlu,
Thank you for the post! Do you have in mind what effect you would like to see from this? This figure looks to be just not have enough points to show the periodic reflection. Could you try to increase the plotting points/sweep points and see whether that could fix the problem?
