Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Adding new material in ANSYS Discovery › Reply To: Adding new material in ANSYS Discovery
Salek Khan
Thank you for your reply. However, when I triple click or select the object from the model tree it does not give me any options to change the material. I just get a box where I can select a material and the only option is structrual steel.
How can you define a new material without using the explore workspace?
Thank you.
