Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › I can’t use fluent because of an error › Reply To: I can’t use fluent because of an error
June 1, 2023 at 2:50 pm
George Karnos
Try the following:
Close all Fluent/Ansys Programs.
Open Windows File Explorer and type in the following in the address line:
%APPDATA%\Ansys
This will take you to your APPDATA\Ansys directory.
You should see a directory named:Â v231Â Â (Or version you are using)
Rename that directory to v231.old
Now try to run.
