Ansys Learning Forum Forums Discuss Simulation Fluids Absence of Low Re Damping option in Spalart-Allmaras Turbulence model Reply To: Absence of Low Re Damping option in Spalart-Allmaras Turbulence model
Pritesh Ramya
Hello Federico!
Thank you for your response.
I must confess I am not aware of the exact version number. However, while I was searching for Low-Re correction/damping option for the Spalart-Allmaras turbulence model, I was directed to the following ANSYS website.
https://www.afs.enea.it/project/neptunius/docs/fluent/html/ug/node435.htm
https://www.afs.enea.it/project/neptunius/docs/fluent/html/ug/node423.htm
The second link provided even showed an interface of Fluent which appeared to be an old version. Since I wanted to see if my results will be influenced on account enabling such an option and since I could not find this option in 2022 R2 version, I posted this question. Could you please provide some more clarification on this? My apologies for any sort of inconvenience. Thank you!
