Ansys Learning Forum Forums Discuss Simulation Fluids how to get a .msh file after optimization with adjoint solver Reply To: how to get a .msh file after optimization with adjoint solver
Aras karimi
I opened the wing STL file in ICEM through the following command:
File => Import Geometry => Faceted => STL.
But I can't select the wing geometry lines.As if they are locked. The geometry wing is displayed on the software screen, but nothing can be done on it.
Has your colleague created a structure mesh with hexahedral elements by creating block on a 3D STL geometry?
