Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › “Low-level communication error -15: Connection was closed” when i run my FSI. › Reply To: “Low-level communication error -15: Connection was closed” when i run my FSI.
May 30, 2023 at 4:19 pm
Hello Federico,
Thank you for your reply.
I am running my FSI using system coupling. When i reran my model on 23R it was the same error message as 19.2. Here is the text i got after analysis initialization.
| Analysis Initialization |
Traceback (most recent call last):
File "PyLib/kernel/remote/RemoteObjects.py", line 28, in _nodeCaller
File "PyLib/physicscoupling/importer/Importer.py", line 36, in setExistingConnection
RuntimeError: Low-level communication error -15: Connection was closed
| Low-level communication error -15: Connection was closed |
File "PyLib/main/Controller.py", line 147, in
File "PyLib/main/Controller.py", line 143, in _run
File "PyLib/main/Controller.py", line 92, in _executeScript
File "PyLib/kernel/commands/__init__.py", line 31, in readScriptFile
File "PyLib/kernel/commands/CommandManager.py", line 169, in readScriptFile
File "wb2cosim.py", line 4, in
Solve()
File "PyLib/kernel/commands/CommandDefinition.py", line 74, in func
File "PyLib/kernel/commands/__init__.py", line 28, in executeCommand
File "PyLib/kernel/commands/CommandManager.py", line 122, in executeCommand
File "PyLib/cosimulation/externalinterface/core/solver.py", line 125, in execute
File "PyLib/cosimulation/solver/__init__.py", line 123, in solve
File "PyLib/kernel/util/Memory.py", line 177, in wrapper
File "PyLib/cosimulation/solver/__init__.py", line 519, in __initializeControlled
File "PyLib/cosimulation/participantmanager/AnsRpcParticipant.py", line 151, in initializeOutputs
File "PyLib/physicscoupling/importer/__init__.py", line 93, in setExistingConnection
File "PyLib/kernel/remote/RemoteObjects.py", line 45, in func
File "PyLib/ComputeNodeCommand.py", line 94, in newfunc
File "PyLib/ComputeNodeCommand.py", line 70, in raiseException
Shutting down System Coupling compute node processes.
