Ansys Learning Forum Forums Discuss Simulation Fluids Symmetry doesn’t work properly Reply To: Symmetry doesn’t work properly
Marius Carrier
I can't show you the whole domain. What exactly are you looking for?
Right now, it is treating the left wall of the geometry as a wall, despite implementing the symmetry condition on the walls. I want the airflow to perceive the left boundary not as a wall, but as a portal to the right wall. It is not an outlet because this would imply that the flow is exiting rather than entering from the right side.
