Ansys Learning Forum Forums Installation and Licensing Ansys Products Aqwa-Geometry update failed Reply To: Aqwa-Geometry update failed
Yu Bi
Hi, could you describe a bit more about how this error message happened? Was the geometry in Aqwa initially OK and after you updated the geometry in the SpaceClaqim, it went wrong? If so, what changes did you make? In the project schematic, can you try to link the geometry cell to a new hydrodynamic diffraction and see if the same error appears?
