Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Solver pivot error with solid/beam model › Reply To: Solver pivot error with solid/beam model
K Kramer
By the way, I get the following warning: "Joints are being used in the current analysis with Large Deflection turned Off.  Thus, only linearized joint behavior will be considered.  If finite rotation and large deflection effects are to be considered, please turn on Large Deflection."
But that should be ok, right?
