Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › ANSYS Mechanical issue › Reply To: ANSYS Mechanical issue
May 26, 2023 at 7:52 am
Saumadeep Choudhury
Hi Avrok,
Can you please send a screenshot of the tree showing the different components you have in SpaceClaim?
It could be due to the reason that you did some operations like “Pull”, where by default the option is to merge the object together unless you select “no merge”.
Take a look at the Pull tool options here: Pull Tool Options (ansys.com)
Saumadeep
