Ansys Learning Forum Forums Discuss Simulation General Mechanical Compression of plates along Reply To: Compression of plates along
ashish.khemka
Can you share what other boundary conditions are applied to the plates? Use 'Asymmetric' behavior for contacts. You can try using a buckling analysis as well to get the load under which plates will buckle.
Buckling | Ansys Innovation Courses
Ashish Khemka
